Item Part No. Description Book Engine 0101 Crankcase 100k03540102 Cylinder Head 100k03540103 Gear Case 100k03540104 Main Bearing Case 100k03540105 Breather 100k0354010601 Air Cleaner 100k0354010602 Air Cleaner Double 100k0354010701 Muffler 100k0354010702 Muffler (Option) 100k03540108 Valve Rocker Arm 100k03540109 Head Cover 100k03540110 Camshaft 100k03540111 Piston Crankshaft 100k03540112 Flywheel 100k03540113 Injection Pump 100k03540114 Fuel Camshaft 100k03540115 Speed Control Plate 100k03540116 Governor 100k03540117 Dynamo 100k03540118 Radiator 100k03540170 Oil Filter 2 [section Parts] 100k03540171 Starter [section Parts] 100k03540172 Nozzle Holder 2 [section Parts] 100k03540173 Dynamo [section Parts] 100k03540174 Injection Pump [section Parts] 100k0354front Axle And Front Wheel 0119 Front Wheel 100k0354steering 012001 Steering Linkage 100k0354012002 Steering Linkage 100k0354front Axle And Front Wheel 012101 Front Axle 100k0354012102 Front Axle 100k0354electrical System 0122 Battery 100k0354clutch 0123 Flywheel Housing 100k03540124 Clutch Housing 100k03540125 Clutch 100k03540126 Clutch Pedal 100k0354steering 012701 Steering 100k03540128 Hand Accel 100k0354bonnet(Hood) And Chassis 0129 Hood 100k03540130 Head Lamp 100k03540131 Seat 100k0354transmission 0132 Transmission Case 100k03540133 Transmission 1 100k03540134 Transmission 2 100k03540135 Transmission 3 100k0354speed Change Lever 0136 Speed Change System 1 100k03540137 Speed Change System 2 100k03540138 Speed Change System 3 100k0354rear Axle And Rear Wheel 0139 Differential System 1 100k03540140 Differential System 2 100k0354014101 Rear Axle (13.6-28) 100k0354014102 Rear Axle (12.4-28) 100k03540142 Axle Case 100k0354brake 0143 Brake 100k03540144 Brake Pedal 100k0354bonnet(Hood) And Chassis 0145 Fender 100k0354electrical System 0146 Electrical 1 100k03540147 Electrical 2 100k03540148 Electrical 3 100k0354fuel System 0149 Fuel Tank 100k03540150 Fuel Filter 100k0354
