Item Part No. Description BookENGINE 01T00101 CRANK CASE 100K033101T00201 OIL PAN 100K033101T00301 PISTON AND CRANKSHAFT 100K033101T00401 MAIN BEARING CASE 100K033101T005 FLYWHEEL 100K033101T00601 CYLINDER HEAD 100K033101T00701 VALVE AND ROCKER ARM 100K033101T00801 NOZZLE AND GLOW PLUG 100K033101T00901 CYLINDER HEAD COVER 100K033101T01001 INLET MANIFOLD 100K033101T01401 CAMSHAFT 100K033101T015 GEAR CASE 100K033101T016 WATER PUMP 100K033101T017 WATER FLANGE AND THERMOSTAT 100K033101T01801 FUEL CAMSHAFT 100K033101T01901 INJECTION PUMP 100K033101T02001 INJECTION PUMP [COMPONENT PARTS] 100K033101T02101 ENGINE STOP LEVER 100K033101T022 SPEED CONTROL PLATE 100K033101T023 GOVERNOR 100K033101T01101 AIR CLEANER 100K033101T01102 DOUBLE AIR CLEANER [OPTION] 100K033101T012 PRE-CLEANER [OPTION] 100K033101T01301 EXHAUST MANIFOLD AND MUFFLER 100K033101T01303 UNDER MUFFLER [OPTION] 100K033101T024 STOP ROD 100K033101T02502 ACCELERATOR LEVER [HYDROSTATIC PS] 100K033101T02601 ACCELERATOR LINKAGE 100K0331FUEL SYSTEM 01T027 FUEL TANK 100K033101T028 FUEL FILTER 100K033101T029 FUEL FILTER [COMPONENT PARTS] 100K0331COOLING WATER SYSTEM 01T03002 FAN 100K033101T031 WATER PIPE 100K033101T03201 RADIATOR 100K033101T033 RESERVE TANK 100K033101T034 SHUTTER 100K0331ELECTRICAL SYSTEM 01T03501 DYNAMO [A] 100K033101T03601 DYNAMO [COMPONENT PARTS] [A] 100K033101T037 STARTER 100K033101T03801 STARTER [COMPONENT PARTS] 100K033101T039 BATTERY 100K033101T040 SWITCH AND REGULATOR 100K033101T041 PANEL 100K033101T042 LIGHT 100K033101T04301 ELECTRICAL WIRING [A] 100K0331CLUTCH 01T04401 CLUTCH 100K033101T045 CLUTCH LEVER 100K033101T046 CLUTCH PEDAL 100K033101T047 CLUTCH HOUSING 100K0331TRANSMISSION 01T048 TRANSMISSION CASE 100K033101T049 MAIN SHAFT 100K033101T050 COUNTER SHAFT 100K033101T051 HYDRAULIC CLUTCH 100K033101T052 SHUTTLE SHAFT 100K033101T053 HI-LO SHAFT 100K033101T05401 PTO COUNTER SHAFT 100K033101T05501 PTO SHAFT [WITH I.MID PTO] [A] 100K033101T056 MID PTO 100K033101T057 REVERSE SHAFT 100K0331SPEED CHANGE LEVER 01T05802 SHUTTLE GEAR SHIFT LEVER [HYDROSTATIC PS] 100K0331
