Kubota G3200 Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01t001 Crankcase 100k011001t002 Oil Pan 100k011001t003 Cylinder Head 100k011001t004 Gear Case 100k011001t005 Main Bearing Case 100k011001t006 Head Cover 100k011001t007 Inlet Manifold 100k011001t008 Valve,rocker Arm 100k011001t009 Camshaft 100k011001t010 Crankshaft 100k011001t011 Flywheel 100k011001t012 Nozzle Holder 100k011001t013 Fuel Camshaft 100k011001t014 Idling Apparatus 100k011001t015 Governor 100k011001t016 Speed Control Plate 100k011001t017 Dynamo 100k011001t018 Water Flange 100k011001t019 Water Pump 100k011001t080 Nozzle Holder [section Parts] 100k0110electrical System 01t081 Dynamo [section Parts] 100k011001t082 Starter [section Parts] 100k0110engine 01t020 Reduction Gear Case 100k0110transmission 01t021 Transmission Case 100k011001t022 Clutch 100k011001t023 Clutch Lever 100k011001t024 Propeller Shaft 100k011001t025 1st Shaft 100k011001t026 4th Shaft 100k011001t027 5th Shaft 100k0110rear Axle 01t028 Differential 100k011001t029 Rear Axle 100k0110speed Change 01t030 Main Speed Change 100k0110brake 01t031 Brake 100k0110transmission 01t032 Pto Shaft 100k011001t033 Tension Pulley 100k0110speed Change 01t034 Pto Lever 100k0110steering 01t035 Steering 100k0110brake 01t036 Brake Pedal 100k0110fuel System 01t037 Accel Lever 100k0110speed Change 01t038 Speed Change Pedal 100k0110engine 01t039 Engine Stop Wire 100k0110hydraulic System 01t040 Lift Shaft 100k011001t041 Lift Link 100k0110bonnet/hood/chassis 01t042 Seat 100k0110labels 01t043 Label 100k0110bonnet/hood/chassis 01t044 Frame 100k011001t045 Fender 100k0110cooling Water System 01t046 Radiator 100k0110fuel System 01t047 Fuel Tank 100k0110bonnet/hood/chassis 01t048 Panel Cover 100k011001t049 Net Holder 100k011001t050 Bonnet 100k0110electrical System 01t051 Electrical System 100k011001t052 Battery 100k0110front Axle 01t053 Front Axle 100k0110​
