Kubota G4200H Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01e01 Crankcase 100k007701e02 Oil Pan 100k007701e03 Cylinder Head 100k007701e04 Gear Case 100k007701e05 Main Bearing Case 100k007701e06 Cylinder Head Cover 100k007701e07 Manifold 100k007701e08 Valve/rocker Arm 100k007701e09 Camshaft 100k007701e10 Piston/crankshaft 100k007701e11 Flywheel 100k007701e12 Nozzle Holder 100k007701e13 Injection Pump 100k007701e14 Idling Apparatus 100k007701e15 Governor 100k007701e16 Speed Control Plate 100k007701e17 Dynamo 100k007701e18 Water Flange 100k007701e19 Water Pump 100k007701e39 Nozzle Holder (Section Parts) 100k007701e40 Injection Pump (Section Parts) 100k007701e41 Dynamo (Section Parts) 100k0077hydraulic System 01i09 Hydraulic Outlet (Option) 100k007701i10 Aux Control Valve (Option) 100k007701i11 3-point Linkage (Option) 100k0077mower Link/drive Belt 01i12 Rear Pto (Option) 100k0077hydraulic System 01i13 Hydraulic Lift (Option) 100k0077transmission 01t01 Transmission Case 100k007701t02 Propeller Shaft 100k007701t03 4th Shaft 100k007701t04 5th Shaft 100k007701t05 Differential 100k0077rear Axle/rear Wheel 01t06 Rear Axle 100k0077brake 01t0701 Brake 100k007701t0702 Brake 100k0077transmission 01t08 Pto Shaft 100k007701t09 Tension Pulley 100k007701t10 Pto Lever 100k007701t11 H.s.t. 100k0077hydraulic System 01t12 Hydraulic Pipe 100k0077steering 01t15 Steering 100k0077brake 01t16 Brake Pedal 100k0077speed Change 01t17 Accel.lever 100k007701t18 Speed Change Lever 100k007701t19 Engine Stop Wire 100k0077mower Link/drive Belt 01t2001 Lift Lever 100k007701t21 Lift Link 100k0077bonnet/hood/chassis 01t2201 Seat 100k007701t2202 Seat 100k0077labels 01t23 Label 100k0077bonnet/hood/chassis 01t24 Frame 100k007701t25 Fender 100k0077cooling Water System 01t26 Radiator 100k0077fuel System 01t27 Fuel Tank 100k0077bonnet/hood/chassis 01t28 Panel Cover 100k007701t29 Radiator Net 100k0077​
