Kubota G6200H Instructions for Parts Books - Instruction Manual
Item Part No. Description Booke Ngine 01e20 Crankcase 100k007901e21 Oil Pan 100k007901e22 Cylinder Head 100k007901e23 Gear Case 100k007901e24 Main Bearing Case 100k007901e25 Cylinder Head Cover 100k007901e26 Manifold 100k007901e27 Valve/rocker Arm 100k007901e28 Camshaft 100k007901e29 Piston/crankshaft 100k007901e30 Flywheel 100k007901e31 Nozzle Holder 100k007901e32 Injection Pump 100k007901e33 Idling Apparatus 100k007901e34 Governor 100k007901e35 Speed Control Plate 100k007901e36 Dynamo 100k007901e37 Water Flange 100k007901e38 Water Pump 100k007901e42 Nozzle Holder (Section Parts) 100k007901e43 Injection Pump (Section Parts) 100k007901e44 Dynamo (Section Parts) 100k0079hydraulic System 01i09 Hydraulic Outlet (Option) 100k007901i10 Aux Control Valve (Option) 100k007901i11 3-point Linkage (Option) 100k0079mower Link/drive Belt 01i12 Rear Pto (Option) 100k0079hydraulic System 01i13 Hydraulic Lift (Option) 100k0079transmission 01t01 Transmission Case 100k007901t02 Propeller Shaft 100k007901t03 4th Shaft 100k007901t04 5th Shaft 100k007901t05 Differential 100k0079rear Axle/rear Wheel 01t06 Rear Axle 100k0079brake 01t0702 Brake 100k0079transmission 01t08 Pto Shaft 100k007901t09 Tension Pulley 100k007901t10 Pto Lever 100k007901t11 H.s.t. 100k0079hydraulic System 01t12 Hydraulic Pipe 100k007901t13 Hydraulic Control Valve 100k007901t14 Hydraulic Lift Cylinder 100k0079steering 01t15 Steering 100k0079brake 01t16 Brake Pedal 100k0079speed Change 01t17 Accel.lever 100k007901t18 Speed Change Lever 100k007901t19 Engine Stop Wire 100k0079mower Link/drive Belt 01t2002 Lift Lever 100k007901t21 Lift Link 100k0079bonnet/hood/chassis 01t2202 Seat 100k0079labels 01t23 Label 100k0079bonnet/hood/chassis 01t24 Frame 100k007901t25 Fender 100k0079cooling Water System 01t26 Radiator 100k0079fuel System 01t27 Fuel Tank 100k0079bonnet/hood/chassis 01t28 Panel Cover 100k007901t29 Radiator Net 100k007901t30 Hood 100k0079​
