Item Part No. Description Book Engine 01t001 Crankcase 100k008501t002 Oil Pan 100k008501t003 Piston/crankshaft 100k008501t004 Main Bearing Case 100k008501t005 Flywheel/starter 100k008501t006 Starter [component Parts] 100k008501t007 Cylinder Head 100k008501t008 Valve/rocker Arm 100k008501t009 Nozzle Holder 100k008501t010 Nozzle Holder [component Parts] 100k008501t011 Head Cover 100k008501t012 Inlet Manifold 100k008501t013 Camshaft 100k008501t014 Gear Case 100k008501t015 Water Pump 100k008501t016 Water Flange 100k008501t017 Fuel Camshaft 100k008501t018 Injection Pump [component Parts] 100k008501t019 Engine Stop Lever,gear Pump 100k008501t020 Hydraulic Pump [component Parts] 100k008501t021 Speed Control Plate 100k008501t022 Governor 100k008501t023 Stop Solenoid 100k0085dynamo 01t024 Dynamo 100k008501t026 Dynamo [component Parts] 100k0085air Cleaner/muffler 01t028 Air Cleaner 100k008501t029 Muffler 100k0085release Rod 01t030 Release Rod 100k0085fuel System 01t031 Fuel Tank 100k008501t032 Fuel Pipe 100k008501t033 Fuel Filter [component Parts] 100k0085radiator System 01t034 Radiator 100k008501t035 Dustproof Net 100k0085electrical System 01t037 Electrical System 2 100k008501t038 Light Kit [udw] 100k0085clutch 01t039 Clutch 100k008501t040 Diff. Lock Clutch Rod 100k008501t041 Clutch Rod 100k008501t042 Clutch Housing Frame 100k0085transmission 01t043 Transmission Case 100k008501t044 Hst 100k008501t045 Hst [component Parts] 100k008501t046 Case Cover 100k008501t047 Second Shaft 100k008501t048 Third Fifth Shaft 100k008501t049 Fourth Shaft 100k0085speed Change Lever 01t050 Speed Change Fork And Pto Lever 100k008501t051 Aux. Speed Change And Front Drive Lever 100k008501t052 Speed Change 1 100k008501t053 Speed Change 2 100k008501t054 Speed Change 3 100k0085front Axle/front Wheel 01t055 Differential 100k008501t056 Axle Case 100k008501t057 Front Axle 100k008501t058 Front Wheel (23 X 10.5-12) 100k0085brake 01t059 Brake 100k0085
