Item Part No. Description Book Engine 01t001 Crankcase 100k008001t002 Oil Pan 100k008001t003 Piston/crankshaft 100k008001t004 Main Bearing Case 100k008001t005 Flywheel 100k008001t006 Cylinder Head 100k008001t007 Valve/rocker Arm 100k008001t008 Nozzle Holder 100k008001t009 Nozzle Holder [component Parts] 100k008001t010 Head Cover 100k008001t011 Inlet Manifold 100k008001t012 Camshaft 100k008001t013 Gear Case 100k008001t014 Water Pump 100k008001t015 Water Flange 100k008001t016 Fuel Camshaft 100k008001t017 Injection Pump [component Parts] 100k008001t018 Engine Stop Lever 100k008001t019 Hydraulic Pump [component Parts] 100k008001t020 Speed Control Plate 100k008001t021 Governor 100k008001t022 Stop Solenoid 100k008001t023 Dynamo 100k008001t024 Dynamo [component Parts] 100k0080clutch 01t037 Clutch 100k0080fuel System 01t025 Air Cleaner 100k008001t026 Muffler 100k008001t027 Release Rod 100k008001t028 Fuel Tank 100k008001t029 Fuel Pipe 100k008001t030 Fuel Filter [component Parts] 100k0080cooling Water System 01t031 Radiator 100k008001t032 Dustproof Plate 100k0080electrical System 01t033 Starter [component Parts] 100k008001t034 Electrical System 1 100k008001t035 Electrical System 2 100k008001t036 Light Kit [option] 100k0080clutch 01t038 Propeller Shaft 100k008001t039 Diff.lock/clutch Rod 100k008001t040 Clutch Rod 100k008001t041 Clutch Housing 100k0080transmission 01t042 Transmission Case 100k008001t043 Hst 100k008001t044 Hst [component Parts] 100k008001t045 Case Cover 100k008001t046 Second Shaft 100k008001t047 Third, Fifth Shaft 100k008001t048 Fourth Shaft 100k0080speed Change Lever 01t049 Speed Change Fork And Pto Lever 100k008001t050 Aux. Speed Change Lever 100k008001t051 Speed Change 1 100k008001t052 Speed Change 2 100k008001t053 Speed Change 3 [old Type] 100k008001t05301 Speed Change 3 [new Type] 100k0080front Axle/front Wheel 01t054 Differential 100k008001t055 Axle Case 100k008001t056 Front Axle 100k008001t057 Front Wheel (23x10.5-12) [adw] 100k0080brake 01t058 Brake 100k008001t059 Pedal 100k0080
