Kubota B20 Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01t001 Crankcase 100k007201t002 Oil Pan 100k007201t003 Piston/crankshaft 100k007201t004 Main Bearing Case 100k007201t005 Flywheel 100k007201t006 Cylinder Head 100k007201t007 Valve/rocker Arm 100k007201t008 Nozzle Holder 100k007201t009 Nozzle Holder [component Parts] 100k007201t010 Cylinder Head Cover 100k007201t011 Inlet Manifold 100k007201t013 Exhaust Manifold 100k007201t015 Camshaft 100k007201t016 Gear Case 100k007201t017 Water Pump 100k007201t018 Water Flange/thermostat 100k007201t019 Fuel Camshaft 100k007201t020 Injection Pump 100k007201t021 Injection Pump [component Parts] 100k007201t022 Engine Stop Lever 100k007201t023 Speed Control Plate 100k007201t024 Governor 100k0072cooling Water System 01t034 Fan 100k0072electrical System 01t035 Dynamo 100k007201t036 Dynamo [component Parts] 100k0072clutch 01t043 Clutch 100k0072hydraulic System 01t087 Hydraulic Gear Pump 100k007201t088 Hydraulic Gear Pump [component Parts] 100k0072engine 01t012 Air Cleaner 100k007201t014 Muffler 100k007201t025 Engine Stop Rod 100k007201t026 Accelerator Lever 100k007201t027 Release Lever 100k0072fuel System 01t028 Fuel Tank 100k007201t029 Fuel Pipe 1 100k007201t030 Fuel Filter [component Parts] 100k007201t031 Fuel Pipe 2 100k0072cooling Water System 01t032 Water Pipe 100k007201t033 Radiator 100k0072electrical System 01t037 Starter 100k007201t038 Starter [component Parts] 100k007201t039 Battery 100k007201t040 Light 100k007201t041 Panel/switch 100k007201t042 Wire Harness 100k0072clutch 01t044 Clutch Rod 100k007201t045 Clutch Pedal 100k007201t046 Clutch Housing 100k007201t047 Transmission Case 100k007201t048 Transmission Case Cover 100k007201t049 Hst 100k007201t050 Hst [component Parts] 100k007201t051 Propeller Shaft 100k007201t052 1st Shaft/2nd Shaft 100k0072transmission 01t053 3rd Shaft 100k007201t054 4th Shaft 100k007201t055 Front Drive Shaft/6th Shaft 100k0072​
