Item Part No. Description Book Engine 01t001 Crankcase 100k031401t002 Oil Pan 100k031401t003 Piston/crankshaft 100k031401t004 Main Bearing Case 100k031401t005 Flywheel 100k031401t006 Cylinder Head 100k031401t007 Valve And Rocker Arm 100k031401t008 Nozzle Holder And Glow Plug 100k031401t009 Nozzle Holder [component Parts] 100k031401t010 Head Cover 100k031401t011 Inlet Manifold 100k031401t013 Exhaust Manifold 100k031401t015 Camshaft 100k031401t016 Gear Case 100k031401t017 Water Pump 100k031401t018 Water Flange/thermostat 100k031401t019 Injection Pump 100k031401t020 Injection Pump [component Parts] 100k031401t021 Speed Control Plate 100k031401t022 Governor 100k031401t023 Fuel Pump 100k031401t024 Lower Gasket Kit 100k031401t025 Upper Gasket Kit 100k0314electrical System 01t034 Dynamo 100k031401t035 Dynamo [component Parts] 100k0314clutch 01t044 Clutch 100k0314hydraulic System 01t083 Hydraulic Gear Pump 100k031401t084 Hydraulic Gear Pump [component Parts] 100k0314engine 02t012 Air Cleaner 100k031402t014 Muffler 100k031402t026 Accelerator Lever 100k0314fuel System 02t027 Fuel Tank 100k031402t028 Fuel Pipe 100k031402t029 Fuel Filter [component Parts] 100k0314cooling Water System 02t030 Water Pipe 100k031402t031 Radiator 100k031402t032 Reserve Tank 100k031402t033 Fan 100k0314electrical System 02t036 Starter 100k031402t037 Starter [component Parts] 100k031402t038 Battery 100k031402t039 Head Light 100k031402t040 Hazard Light/tail Light 100k031402t041 Meter/switch 100k031402t04102 Meter Kit 100k031402t042 Meter [component Parts] 100k031402t043 Wire Harness 100k0314clutch 02t045 Clutch Rod 100k031402t046 Clutch Pedal 100k031402t047 Clutch Housing 100k0314transmission 02t048 Clutch Shaft/propeller Shaft 100k031402t049 Transmission Case 100k031402t050 Differential Gear Case 100k031402t051 Hst 100k031402t052 Hst [component Parts] 100k031402t053 2nd/3rd/4th Shaft 100k031402t054 5th Shaft/pto Shaft 100k0314
