Item Part No. Description Book Engine 010001 Crank Case 100a0079010002 Oil Pan 100a0079010003 Cylinder Head 100a0079010004 Gear Case 100a0079010005 Head Cover 100a0079010100 Main Bearing Case 100a0079010101 Camshaft And Idle Gear Shaft 100a0079010102 Piston And Crank Shaft 100a0079010103 Flywheel 100a0079010105 Fuel Camshaft And Governor Shaft 100a0079010201 Stop Solenoid 100a0079010202 Injection Pump 100a0079010203 Injection Pump [component Parts] 100a0079010204 Governor 100a0079010205 Speed Control Plate 100a0079010206 Nozzle Holder And Glow Plug 100a0079010207 Nozzle Holder [component Parts] 100a0079010500 Water Flange And Thermostat 100a0079010501 Water Pump 100a0079010600 Valve And Rocker Arm 100a0079010601 Inlet Manifold 100a0079010602 Exhaust Manifold 100a007901090001 Upper Gasket Kit 100a007901090002 Lower Gasket Kit 100a0079electrical System 01a521 Dynamo 100a007901a523 Dynamo [component Parts] 100a0079clutch 01c101 Clutch 100a0079hydraulic System 01j120 Hydraulic Pump 100a007901j125 Hydraulic Pump [component Parts] 100a0079engine 02060301 Air Cleaner 100a007902060302 Air Cleaner 100a007902060303 Air Cleaner (Double) [option] 100a0079020605 Muffler 100a0079fuel System 02a001 Accelerator Lever 100a007902a101 Fuel Tank 100a007902a110 Fuel Pipe 100a007902a130 Fuel Filter [component Parts] 100a0079cooling Water System 02a401 Fan 100a007902a410 Water Pipe 100a007902a420 Radiator 100a0079electrical System 02a525 Starter 100a007902a530 Starter [component Parts] 100a007902a535 Battery 100a007902b115 Panel Board 100a007902b120 Panel Board [component Parts] 100a007902b301 Head Light 100a007902b302 Tail Light/hazard Light/working Light 100a007902b50101 Electrical Wiring 100a0079clutch 02c110 Clutch Rod 100a007902c301 Clutch Pedal 100a007902c401 Clutch Housing 100a0079frame 02c415 Frame 100a0079transmission 02c420 Transmission Case 100a007902c425 Differential Gear Case 100a007902c427 Rear Axle Case 100a007902d001 Clutch Shaft/proreller Shaft 100a0079
