Problem with ignition
Ardikov1
Hi everyone, i have a problem with ignition switch. My key was stolen and I tried to turn on with wires but excavator won’t shut down and started to get throttle. Do i need just to change the ignition lock or code something. Thanks alot.
KX080-3 The model 2008​
Heads up. You messed up the key switch, and the throttle went wild. Stop it with the fuel shutoff or emergency stop. Swap out the ignition switch, and be sure to rewire it right using the diagram. If your ride has a security system, you might need to get it reprogrammed.
