I've been on my RTV500 the past couple of weeks trying to track down a stubborn no start issue. The engine cranks fine, but I'm not getting consistent spark. I've worked my way through the basics, battery, connections, plugs, and grounds all check out, but I keep coming back to the ignition coil as the likely culprit.
The problem is, before I go ordering parts, I'd really like to test the coil properly, got a decent multimeter on hand, but I can't seem to find reliable ohm spec numbers for the primary and secondary readings on this machine.
This RTV has been my little workhorse for hauling firewood and checking fences, so I'd love to get it back up and running
Does anyone here have the proper coil resistance specs for the RTV500, or maybe a service manual reference?
