SERVICING OF TRACTORYour dealer is interested in your new tractor and has thedesire to help you get the most value from it. After readingthis manual thoroughly, you will find that you can do someof the regular maintenance yourself.However, when in need of parts or major service, be sure tosee your KUBOTA dealer.For service, contact the KUBOTA Dealership from whichyou purchased your tractor or your local authorizedKUBOTA dealer.When in need of parts, be prepared to give your dealer boththe tractor and engine serial numbers.The tractor serial number is located on the transmissionhousing on the right-hand side of the tractor. The engineserial number is located on the engine crankcase, right side.Locate the serial numbers now and record them in the spaceprovided.KUBOTA L235/L235DT/L275/ L275DTTractor Serial No.Engine Serial No.Date of Purchase(To be filled in by purchaser)
