1. DASHBOARD & CONTROLS1.1. DashboardControl Panel (1)Oil Pressure Warning LightThis light warns against any drop in engine oil pressure. It will illuminate when the ignition switch isin the ON position and in normal operation will extinguish once the engine is running.Battery Charging LightThis light warns against insufficient battery charging. It will illuminate when the ignition switch is inthe ON position and in normal operation will extinguish once the engine is running.1. Control panel2. Hour meter3. Light switch4. Indicator switch5. Decompression lever6. Glow plug indicator7. Horn8. Ignition switch9. Engine stop switch1. Engine rev counter (RPM)2. Oil pressure warning light (OIL)3. Battery charging light (CHG)
