Kubota GR2120EU Workshop Manual Printed in Japan 2011, KiSC issued 07, 2011 A - Code No.9Y111-05980 - Technical Manual
BEFORE YOU START SERVICE• Read all instructions and safety instructions in thismanual and on your machine safety decals.• Clean the work area and machine.• Park the machine on a stable and level ground, andset the parking brake.• Lower the implement to the ground.• Stop the engine, then remove the key.• Disconnect the battery negative cable.• Hang a "DO NOT OPERATE" tag in the operatorstation.WSM000001INI0010US1START SAFELY• Do not do the procedures below when you start theengine.– short across starter terminals– bypass the safety start switch• Do not alter or remove any part of machine safetysystem.• Before you start the engine, make sure that all shiftlevers are in neutral positions or in disengagedpositions.• Do not start the engine when you stay on the ground.Start the engine only from operator's seat.WSM000001INI0015US0 SAFETY FIRST• This symbol, the industry's "Safety Alert Symbol", is used throughout this manual and on labels on themachine itself to warn of the possibility of personal injury. Read these instructions carefully.• It is essential that you read the instructions and safety regulations before you attempt to repair or usethis unit. DANGER• Indicates an imminently hazardous situation which, if not avoided, will result in death or serious injury. WARNING• Indicates a potentially hazardous situation which, if not avoided, could result in death or serious injury. CAUTION• Indicates a potentially hazardous situation which, if not avoided, may result in minor or moderateinjury.IMPORTANT• Indicates that equipment or property damage could result if instructions are not followed.NOTE• Gives helpful information.KiSC issued 07, 2011 AGR2120EU, WSM INFORMATIONI-2OPERATE SAFELY• Do not use the machine after you consume alcoholor medication or when you are tired.• Put on applicable clothing and safety equipment.• Use applicable tools only. Do not use alternativetools or parts.• When 2 or more persons do servicing, make surethat you do it safely.• Do not operate below the machine that only a jackholds. Always use a safety stand to hold themachine.• Do not touch the hot parts or parts that turn when theengine operates.• Do not remove the radiator cap when the engineoperates, or immediately after it stops. If not, hotwater can spout out from the radiator. Only removethe radiator cap when it is at a sufficiently lowtemperature to touch with bare hands. Slowly loosenthe cap to release the pressure before you remove itfully.• Released fluid (fuel or hydraulic oil) under pressurecan cause damage to the skin and cause seriousinjury. Release the pressure before you disconnecthydraulic or fuel lines. Tighten all connections beforeyou apply the pressure.• Do not open a fuel system under high pressure.The fluid under high pressure that stays in fuel linescan cause serious injury. Do not disconnect or repairthe fuel lines, sensors, or any other componentsbetween the fuel pump and injectors on engines witha common rail fuel system under high pressure.• Put on an applicable ear protective device (earmuffsor earplugs) to prevent injury against loud noises.• Be careful about electric shock. The enginegenerates a high voltage of more than DC100 V inthe ECU and is applied to the injector​
