SAFETY FIRST BEFORE YOU START SERVICE Read all instructions and safety instructions in thismanual and on your machine safety decals. Clean the work area and machine. Park the machine on a stable and level ground, andset the parking brake. Lower the implement to the ground. Stop the engine, then remove the key. Disconnect the battery negative cable. Hang a "DO NOT OPERATE" tag in the operatorstation.WSM000001INI0010US1START SAFELY Do not do the procedures below when you start theengine. short across starter terminals bypass the safety start switch Do not alter or remove any part of machine safetysystem. Before you start the engine, make sure that all shiftlevers are in neutral positions or in disengagedpositions. Do not start the engine when you stay on the ground.Start the engine only from operator's seat.WSM000001INI0015US0 SAFETY FIRST This symbol, the industry's "Safety Alert Symbol", is used throughout this manual and on labels on themachine itself to warn of the possibility of personal injury. Read these instructions carefully. It is essential that you read the instructions and safety regulations before you attempt to repair or usethis unit. DANGER Indicates an imminently hazardous situation which, if not avoided, will result in death or serious injury. WARNING Indicates a potentially hazardous situation which, if not avoided, could result in death or serious injury. CAUTION Indicates a potentially hazardous situation which, if not avoided, may result in minor or moderateinjury.IMPORTANT Indicates that equipment or property damage could result if instructions are not followed.NOTE Gives helpful information.
