Kubota T1600H Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01t01 Crankcase 100k051801t02 Oil Pan 100k051801t03 Piston/crankshaft 100k051801t04 Main Bearing Case 100k051801t05 Flywheel 100k051801t06 Cylinder Head 100k051801t07 Valve/rocker Arm 100k051801t08 Nozzle Holder 100k051801t09 Nozzle Holder [component Parts] 100k051801t10 Head Cover 100k051801t11 Inlet Manifold 100k051801t13 Exhaust Manifold 100k051801t15 Camshaft 100k051801t16 Gear Case 100k051801t17 Water Pump 100k051801t18 Water Flange 100k051801t19 Injection Pump 100k051801t20 Injection Pump [component Parts] 100k051801t21 Speed Control Plate 100k051801t22 Governor 100k051801t23 Stop Solenoid 100k051801t24 Upper Gasket Kit 100k051801t25 Lower Gasket Kit 100k0518radiator System 01t30 Fan 100k0518electrical System 01t31 Dynamo/starter 100k051801t32 Dynamo [component Parts] 100k0518engine 02t12 Air Cleaner 100k051802t14 Muffler 100k0518fuel System 02t26 Fuel Tank 100k051802t27 Fuel Pipe 100k0518radiator System 02t28 Water Pipe 100k051802t29 Radiator 100k0518electrical System 02t33 Starter [component Parts] 100k051802t34 Battery 100k051802t35 Light 100k051802t36 Dashboard 100k051802t37 Wire Harness 100k0518transmission 02t3801 Hst Transaxle 100k051802t3802 Hst Transaxle 100k051802t3901 Hst Transaxle [component Parts] 100k051802t3902 Hst Transaxle [component Parts] 100k051802t40 Universal Joint/hst Fan 100k051802t4001 Universal Joint/hst Fan 100k0518pto System 02t41 Pto Shaft 100k051802t42 Tension Pulley 100k051802t43 Belt Retainer 100k0518speed Change 02t44 Speed Change Rod 100k051802t45 Speed Change Pedal 100k0518wheel 02t46 Rear Wheel (20 X 10.00-8) / Front Wheel (15 X 6.00-6) 100k0518brake 02t47 Brake Rod 100k051802t48 Brake Pedal 100k0518front Axle/frame 02t49 Front Axle 100k051802t50 Frame 100k0518steering 02t51 Steering 100k0518mower Link 02t52 Lift Lever 100k051802t53 Lift Link 100k051802t54 Link 100k0518bonnet/hood/chassis 02t55 Hood 100k051802t56 Panel 100k051802t57 Fender 100k0518​
