Kubota RCK44LT Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Mower 01g001 Mower Deck 100k025201g002 Blade/cover 100k025201g003 Gauge Wheel 100k0252 Ref.no Part No. Description Q'ty S.no. I/c Remarks Weight(Kgf)weight(Lb)010 K5142-97120 Kit Mower Deck 1 0 0020 K5142-71550 Arm Tension 1 0 0030 08511-02530 Bushing 1 0.03 0.066040 K5112-71650 Pulley Tension 1 (4.0) 0.53 1.166050 0y169-50628 Bolt Short Squ.necx 1 (3/8-24unf) 0 0060 75599-33013 Washer Spring Lock 1 (3/8) 0 0070 K5112-71660 Cover Tension 1 0.018 0.0396080 75599-31023 Hex. Nut 1 (3/8-24unf) 0.006 0.0132090 K5142-72740 Spring Tension 1 0 0100 K5142-71240 Pulley 1 5.5-7.25 0 0110 08141-06205 Bearing 2 0.118 0.2596120 K5112-71280 Cover Bearing 2 0.004 0.0088130 04612-00250 Circlip 2 (25) 0.002 0.0044140 K5112-71480 Washer Plain 1 0.006 0.0132150 K5112-71290 Retainer Belt 1 0.13 0.286160 01053-50818 Hex. Bolt 1 (M8 X 1.25 X 18) 0.011 0.0242170 75599-33012 Washer Spring Lock 1 (5/16) 0.002 0.0044180 K5142-51310 V-belt 1 71 0 0190 K5112-71650 Pulley Tension 1 (4.0) 0.53 1.166200 0y169-50628 Bolt Short Squ.necx 1 (3/8-24unf) 0 0210 75599-33013 Washer Spring Lock 1 (3/8) 0 0220 K5112-71660 Cover Tension 1 0.018 0.0396230 75599-31023 Hex. Nut 1 (3/8-24unf) 0.006 0.0132240 K5142-71710 Bracket Pulley 1 0 0250 01053-50818 Bolt Hex 4 (M8 X 1.25 X 18l) 0.011 0.0242260 75599-33012 Washer Spring Lock 4 (5/16) 0.002 0.0044270 K5142-44350 Link 4 2 0 0280 K5112-73110 Label Danger 1 1 0 0290 K5112-73120 Label Danger 2 1 0 0300 01754-50814 Bolt Flange 3 >=30001 0.005 0.011310 02751-50080 Nut Flange 3 >=30001 0.006 0.0132
