This symbol, the industry's "Safety Alert Symbol" is used throughout this manual and on labels on the machineitself to warn of the possibility of personal injury. Read these instructions carefully.It is essential that you read theinstructions and safety regulations before you attempt to repair or use this unit.A Indicates an imminently hazardous situation which, if not avoided, will result in death or serious injury.A Indicates a potentially hazardous situation which, if not avoided, could result in death or serious injury.A Indicates a potentially hazardous situation which, if not avoided, may result in minor or moderate injury.A Indicates that equipment or property damage could result if instructions are not followed.A Gives helpful information. BEFORE SERVICING AND REPAIRINGA Read all instructions and safety instructions in thismanual and on your machine safety decals.A Clean the work area and machine.A Park the machine on a firm and level ground, and setthe parking brake.A Lower the implement to the ground.A Stop the engine, and remove the keyA Disconnect the battery negative cableA Hang a "DO NOT OPERATE" tag in operatorstation.SAFETY STARTINGA Do not start the engine by shorting across starterterminals or bypassing the safety start switch.A Do not alter or remove any part of machine safetysystem.A Before starting the engine, make sure that all shiftlevers are in neutral positions or in disengagedpositions.A Never start the engine while standing on ground.Start the engine only from operator's seat.
