This symbol, the industry's "Safety Alert Symbol", is used throughout this manual and on labels on the machine itself to warn of the possibility of personal injury. Read these instructions carefully.It is essential that you read the instructions and safety regulations before you attempt to repair or use this unit. DANGER : Indicates an imminently hazardous situation which, if not avoided, will result in death or serious injury. WARNING : Indicates a potentially hazardous situation which, if not avoided, could result in death or serious injury.CAUTION : Indicates a potentially hazardous situation which, if not avoided, may result in minor or moderate injury.■ IMPORTANT : Indicates that equipment or property damage could result if instructions are not followed.■ NOTE : Gives helpful information. BEFORE SERVICING AND REPAIRING• Read all instructions including safety instructions in this manual and your machine safety decals.• Clean the work area and machine.• Park the machine on firm and level ground, and set the parking brake.• Lower the implement to the ground.• Stop the engine, and remove the key.• Disconnect the battery negative cable.• Hang a "DO NOT OPERATE" label on the operators platform. BEFORE SERVICING AND REPAIRING• Read all instructions including safety instructions in this manual and your machine safety decals.• Clean the work area and machine.• Park the machine on firm and level ground, and set the parking brake.• Lower the implement to the ground.• Stop the engine, and remove the key.• Disconnect the battery negative cable.• Hang a "DO NOT OPERATE" label on the operators platform.
