This symbol, the industry's "Safety Alert Symbol" is used throughout this manual and on labels on the machineitself to warn of the possibility of personal injury. Read these instructions carefully.It is essential that you read theinstructions and safety regulations before you attempt to repair or use this unit.A Indicates an imminently hazardous situation which, if not avoided, will result in death or serious injury.A Indicates a potentially hazardous situation which, if not avoided, could result in death or serious injury.A Indicates a potentially hazardous situation which, if not avoided, may result in minor or moderate injury.A Indicates that equipment or property damage could result if instructions are not followed.A Gives helpful information. BEFORE SERVICING AND REPAIRINGA Read all instructions and safety instructions in thismanual and on your engine safety decals.A Clean the work area and engine.A Park the machine on a firm and level ground.A Allow the engine to cool before proceeding.A Stop the engine, and remove the keyA Disconnect the battery negative cableSAFETY STARTINGA Do not start the engine by shorting across starterterminals or bypassing the safety start switch.A Unauthorized modifications to the engine may impairthe function and / or safety and affect engine life
