Kubota GF1800E Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01t001 Crankcase 100k017401t002 Oil Pan 100k017401t003 Piston/crankshaft 100k017401t004 Main Bearing Case 100k017401t005 Flywheel 100k017401t006 Cylinder Head 100k017401t007 Valve/rocker Arm 100k017401t008 Nozzle Holder/glow Plug 100k017401t009 Nozzle Holder [component Parts] 100k017401t010 Head Cover 100k017401t011 Inlet Manifold 100k017401t013 Exhaust Manifold 100k017401t015 Camshaft 100k017401t016 Gear Case 100k017401t017 Water Pump 100k017401t018 Water Flange 100k017401t019 Injection Pump 100k017401t020 Injection Pump [component Parts] 100k017401t021 Speed Control Plate 100k017401t022 Governor 100k017401t023 Solenoid 100k017401t024 Gasket Kit 100k0174electrical System 01t031 Dynamo 100k017401t032 Dynamo [component Parts] 100k0174engine 02t012 Air Cleaner 100k017402t014 Muffler 100k017402t025 Accelerator Lever 100k0174fuel System 02t026 Fuel Tank 100k017402t027 Fuel Pipe 100k0174cooling Water System 02t028 Panel Screen 100k017402t029 Radiator 100k017402t030 Fan 100k0174electrical System 02t033 Starter 100k017402t034 Starter [component Parts] 100k017402t035 Battery 100k017402t036 Electrical Instrument 100k017402t037 Wire Harness 100k0174transmission 02t038 Transmission Case 100k017402t039 Hst 100k017402t040 Hst [component Parts] 100k017402t041 Universal Joint/fan 100k017402t042 Pto Gear Case 100k017402t043 One-way Shaft 100k017402t044 Pto Clutch/pto Shaft 100k0174speed Change 02t045 Pto Lever 100k017402t046 Cruise Control Plate 100k017402t047 Cruise Control Lever 100k017402t048 Speed Control Pedal 100k0174front Axle 02t04901 Differential 100k017402t050 Differential Lock Shaft 100k017402t05101 Differential Lock Pedal 100k017402t052 Front Axle Case 100k017402t053 Front Axle 100k017402t054 Front Wheel (20 X 10.00-8) 100k0174brake 02t05501 Brake Shaft 100k017402t05601 Brake 100k017402t057 Brake Rod 100k017402t058 Brake Pedal 100k0174rear Axle 02t059 Rear Axle/knuckle Arm 100k017402t060 Rear Wheel (16 X 6.50-8) 100k0174​
