Kubota G1800S Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01g001 Crankcase 100k018001g002 Oil Pan 100k018001g003 Piston/crankshaft 100k018001g004 Main Bearing Case 100k018001g005 Flywheel 100k018001g006 Cylinder Head 100k018001g007 Valve/rocker Arm 100k018001g008 Nozzle Holder/glow Plug 100k018001g009 Nozzle Holder [component Parts] 100k018001g010 Head Cover 100k018001g011 Inlet Manifold 100k018001g013 Exhaust Manifold 100k018001g015 Camshaft 100k018001g016 Gear Case 100k018001g017 Water Pump 100k018001g018 Water Flange/thermostat 100k018001g019 Injection Pump 100k018001g020 Injection Pump [component Parts] 100k018001g021 Speed Control Plate 100k018001g022 Governor 100k018001g023 Stop Solenoid 100k018001g024 Upper Gasket Kit 100k018001g025 Lower Gasket Kit 100k018002g012 Air Cleaner 100k018002g014 Muffler 100k018002g026 Accelerator Lever 100k0180fuel System 02g052 Fuel Tank 100k018002g053 Fuel Pipe 100k0180cooling Water System 02g055 Radiator 100k018002g056 Fan 100k0180electrical System 02g057 Dynamo 100k018002g058 Dynamo [component Parts] 100k018002g059 Starter [component Parts] 100k018002g060 Starter [component Parts] 100k018002g062 Battery 100k018002g064 Light 100k018002g065 Dashboard 100k018002g066 Dashboard 100k018002g068 Wire Harness 100k0180transmission 02g070 Transmission Case 100k018002g071 Hst 100k018002g072 Hst [component Parts] 100k018002g073 Universal Joint/hst Fan 100k018002g074 Universal Joint/hst Fan 100k018002g075 Pto Shaft 100k018002g076 Tension Pulley 100k018002g077 Belt Retainer 100k018002g078 Rear Pto 100k018002g079 Rear Pto [component Parts] 100k0180speed Change 02g080 Cruise Control Plate 100k018002g081 Cruise Control Lever 100k018002g082 Speed Control Pedal 100k0180rear Axle 02g083 Rear Differential 100k018002g084 Rear Axle Case 100k018002g087 Rear Axle [4ws] 100k018002g088 Rear Axle Joint [4ws] 100k018002g089 Knuckle Arm [4ws] 100k0180​
