Kubota G1800_Revised Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01g001 Crankcase 100k017901g002 Oil Pan 100k017901g003 Piston/crankshaft 100k017901g004 Main Bearing Case 100k017901g005 Flywheel 100k017901g006 Cylinder Head 100k017901g007 Valve/rocker Arm 100k017901g008 Nozzle Holder/glow Plug 100k017901g009 Nozzle Holder [component Parts] 100k017901g010 Head Cover 100k017901g011 Inlet Manifold 100k017901g013 Exhaust Manifold 100k017901g015 Camshaft 100k017901g016 Gear Case 100k017901g017 Water Pump 100k017901g018 Water Flange/thermostat 100k017901g019 Injection Pump 100k017901g020 Injection Pump [component Parts] 100k017901g021 Speed Control Plate 100k017901g022 Governor 100k017901g023 Stop Solenoid 100k017901g024 Upper Gasket Kit 100k017901g025 Lower Gasket Kit 100k017902g012 Air Cleaner 100k017902g014 Muffler 100k017902g026 Accelerator Lever 100k0179fuel System 02g052 Fuel Tank 100k017902g053 Fuel Pipe 100k0179cooling Water System 02g055 Radiator 100k017902g056 Fan 100k0179electrical System 02g057 Dynamo 100k017902g058 Dynamo [component Parts] 100k017902g059 Starter [component Parts] 100k017902g060 Starter [component Parts] 100k017902g062 Battery 100k017902g064 Light 100k017902g065 Dashboard 100k017902g066 Dashboard 100k017902g068 Wire Harness 100k0179transmission 02g070 Transmission Case 100k017902g071 Hst 100k017902g072 Hst [component Parts] 100k017902g073 Universal Joint/hst Fan 100k017902g074 Universal Joint/hst Fan 100k017902g075 Pto Shaft 100k017902g076 Tension Pulley 100k017902g077 Belt Retainer 100k017902g078 Rear Pto 100k017902g079 Rear Pto [component Parts] 100k0179speed Change 02g080 Cruise Control Plate 100k017902g081 Cruise Control Lever 100k017902g082 Speed Control Pedal 100k0179rear Axle 02g083 Rear Differential 100k017902g084 Rear Axle Case 100k017902g085 Rear Axle [2ws] 100k017902g086 Rear Wheel (23 X 10.5-12) [2ws] 100k0179brake 02g093 Pto Brake 100k017902g094 Brake Shaft 100k017902g095 Brake 100k017902g096 Brake Rod 100k0179​
