BX2660 tires due for replacement
For the BX2660, from experience, the Carlisle Super Lug or Galaxy Hulk is a solid choice for everyday use since they offer great traction and can hold up well over time. For turf jobs, the Carlisle Tru Power would be a smart pick. If you find yourself on mixed terrains, the Titan Trac Loader R4 pattern performs nicely.
Looking to swap out the stock tires too. Mostly run on compacted soil and gravel, but I do some light turf work around the garden. Would the Super Lug be too aggressive for that mix, or should I lean toward the R4s?
If you're mostly on compacted soil and gravel, the R4s probably strike the best balance. Have you noticed if the soil gets slick after rain? That might help decide whether you'll need the extra bite of the Super Lugs.
It depends on your preference and use. I found a comparison between tire options, you might consider checking this.
