Starting and stopping Kubota Z726X
MEMELord
Member
I'm having a weird issue with my Kubota Z726X. It starts up fine and runs great for about 30 minutes, but then it starts acting like it's running out of fuel. I've checked and replaced everything I can think of - fuel filter, fuel pump, fuel lines, even the coils.
The weird thing is, after it cools down for a bit, I can get another 10-30 minutes of run time. It's driving me crazy! Does anyone have any ideas what might be causing this?
If your engine stalls as soon as you stop spraying carb cleaner, you probably have a fuel delivery issue.
If it doesn't fire up after spraying carb cleaner, it's more likely an electrical or valve problem. Let us know what happens!
The fuel tank has a valve on top of it. Remove it and check if it's clean. If it's dirty or old, then I think it's time for you to replace. That could solve the issue.
