stoneCold.
- Jan 9, 2026
just bought a 2020 Kubota KX040-4 was sucking air and dying at high idle. I fixed a leaky water separator bowl, but now I’m seeing weird constant vacuum on the system. like -10 to -20 psi at full throttle
I’ve replaced the filters, swapped the pump, added a second inline pump, and even cleaned the tank, no change
the only way I can get the pressure to rise is by pinching the injector return lines, but then it just throws a fuel pressure code.
It feels like it’s bypassing too much fuel back to the tank instead of holding pressure
has anyone dealt with this? am I missing a relief valve or something in the return circuit?
