Rear remotes for my Kubota M62
Belen03
I'm stumped on where to hook up the hydraulic hoses for my Fit Rite rear remotes on my M62. I can't find any Kubota manuals that show where the valve body lines go. Any tips would be greatly appreciated.
This post is from last October. Is your system operational now?
The M62 presents a unique challenge because it is a dedicated TLB with a closed-center hydraulic system, which differs from the simpler setups on standard utility tractors. To add remotes (additional hydraulic controls) correctly, you must integrate the new valve into the power-beyond circuit (a hydraulic path allowing fluid to flow to other functions), usually located at the main loader valve assembly. A power-beyond sleeve or adapter is required to ensure hydraulic oil continues to flow downstream to the loader and backhoe after your new remote valve.
Did the Fit Rite kit specify it was for the M62 TLB platform, and have you identified the primary loader control valve block under the operator's floor plate?
