Item Part No. Description Book Engine 010001 Crank Case 100a0236010002 Oil Pan 100a0236010003 Cylinder Head 100a0236010102 Crankshaft 100a0236010103 Flywheel 100a0236010201 Fuel Filter 100a0236010202 Carburettor 100a0236010205 Speed Control Plate 100a0236010404 Starter 100a0236010507 Blower Housing & Buffles 100a0236010603 Air Cleaner 100a0236020605 Muffler 100a0236010606 Exhaust System 100a0236010608 Universal Joint 100a0236010809 Label 100a023602a010 Accelerator Lever 100a0236fuel System 02a101 Fuel Tank 100a023602a110 Fuel Pipe 100a0236electrical System 02a535 Battery 100a023602b101 Switch 100a023602b105 Switch/sensor 100a023602b115 Panel Board 100a023602b230 Electrical Wiring 100a0236clutch Transmission Rear Axle 02c420 Transmission Case 100a023602c422 Charge Pump Case 100a023602c423 Center Cover 2 100a023602c440 Hst 100a023602c452 Hst Rh 1 [component Parts] 100a023602c453 Hst Rh 2 [component Parts] 100a023602c454 Hst Rh 3 [component Parts] 100a023602c455 Hst Lh [component Parts] 100a023602c456 Hst Lh 1 [component Parts] 100a023602c457 Hst Lh 1 [component Parts] 100a023602c458 Hst Lh 2 [component Parts] 100a023602c459 Hst Lh 4 [component Parts] 100a023602d001 Clutch Shaft 100a023602d110 Input Shaft 100a0236brake/speed Change Lever 02e005 Brake Rod 100a023602e010 Parking Brake Lever 100a023602f130 Pto Gear Shift Lever 100a023602f141 Speed Control Lever Rh 100a023602f142 Speed Control Lever Lh 100a023602f147 Speed Control Rod 2 100a0236front Axle 02g110 Front Axle 100a0236hydraulic System 02j230 Pto Hydraulic Oil Line 100a023602j240 Hydraulic Pipe (Hst) 100a023602k105 Lift Cylinder 100a023602l103 Mower Lift Arm 100a0236chassis 02m005 Main Frame 100a023602m015 Engine Support 100a023602m020 Adjuster Handle 100a023602m025 Lift Up Adjuster 100a0236hood/bonnet 02m103 Front Mask 100a023602m105 Hood (Bonnet) 100a023602m210 Fender 100a023602m220 Seat 100a023602m224 Seat Base 100a023602m225 Step 100a023602m301 Rops 100a0236
