Kubota Tractor Models M4900,M5700,M5700HD Workshop Manual Printed in Japan 2020 Code No.9Y011-12555—KiSC issued 03, 2020 A - Technical Manual
SAFETY INSTRUCTIONS M4900 . M5700 WSM, 12550 SAFETY FIRST This symbol, the industry's "Safety Alert Symbol", is used throughout this manual and decals on the machine itself to warn of the possibility of personal injury. Read these instructions carefully. It is essential that you read the instructions and safety regulations before you attempt to repair or use this unit. DANGER :Indicates an imminently hazardous situation which, if not avoided, will result in death or serious injury. WARNING: Indicates a potentially hazardous situation which, if not avoided, could result in death or serious injury. CAUTION : Indicates a potentially hazardous situation which, if not avoided, may result in minor or moderate injury. IMPORTANT :Indicates that equipment or property damage could result if instructions are not followed. NOTE : Gives helpful information. STOP Kubota 00000Z00010 BEFORE SERVICING AND REPAIRING (1) Read all instructions and safety instructions in this manual and on your machine safety decals. (2) Clean the work area and machine. (3) Park the machine on a firm and level ground, and set the parking brake. (4) Lower the implement to the ground. (5) Stop the engine, and remove the key. (6) Disconnect the battery negative cable. (7) Hang a "DO NOT OPERATE" tag in operator station.​
