Kubota Model L1720 Loader for Tractor Models L305, L305DT, L345, L345DT, L355SS Parts and Service Form 70000-70024 Rev. B 4-1-82 - Instruction Manual
(A) Maximum Lift Height.a(B) Clearnace With Attachment Dumped(C) Reach At Maximum Height.(D) Maximum Dump Angle..(E) Reach With Attachment On Ground(F) Attachment Rollback Angle..(G) Digging Depth.(H) Overall Height To Carry Positionbreak-away Capacitylift Capacity At Full Heightraising Time..lowering Time.attachment Dumping Timeattachment Roll Back Time.kubota L345dt Tractorand Loader Equippedwith External (Open Center-2000 Psi) Hydraulicpump System; Front Tiresize 9.5-16; Rear Tire Size13.6-28; And 66" Materialbucket Less Tines. Specifications Will Vary Fortractors And Loaderequipped Differently.113.5" (2883mm).89.75" (2280mm)..39"(991mm)....45°.72.25"(1835mm)...17.7.5" (191mm).60.25" (1530mm)2550 Lbs. (1150kg)1495 Lbs. (680kg).4.3 Sec..3.3 Sec..3.0 Sec.'.2.5 Sec.kubota L305dt Tractor Andloader Equipped With Eхternal (Open Center-1800psi) Hydraulic Pump System; Front Tire Size 8-16; Reartire Size 13.6-24; And 66" Material Bucket Less Tines.specifications Will Vary Fortractors And Loader Equipped Differently.111.5" (2832mm).89.5" (2273mm).36" (914mm)45.76.8" (1951mm).20...8" (203mm).57.3" (1455mm). 2220 Lbs. (1010kg)1300 Lbs. (590kg).4.5 Sec..3.4 Sec..4.3 Sec...2.3 Sec.1433 Lbs. (615kg)kubota L355ss Tractor Andloader Equipped With External (Open Center-2000psi) Hydraulic Pump System; Front Tire Size 8.3-16;rear Tire Size 13.6-24; And66" Material Bucket Lesstines. Specifications Willvary For Tractors And Loaderequipped Differently..112" (2845mm).91" (2320mm)73.38"(965mm)42°(1845mm)21..5" (120mm)....63.5" (1615mm)2360 Lbs. (1070kg). 1470 Lbs. (669kg).4.8 Sec.2.13.7sec.sec..2.5 Sec.*1433 Approx. Shipping Weight (With Attachment). 1433 Lbs. (651kg) 33 Lbs. (651kg)cylinders:"Using External Hydraulic System @ 2800 Rpm. Tractor System Will Be Slower.number - Type Lift Cylinders Number - Type Bucket Cylinders.port Thread Spec'svalve:external Hydraulic Control Valve Made By Cross.rated Capacity.rated Pressureport Thread Spec'srelief Valve Settingl305 & L305dt External Hydraulic System..2-2" Dia. Bore With 1.50" Dia. Rod, 27.25" Stroke.2-2" Dia. Bore With 1.25" Dia. Rod, 22.25" Stroke34"-16 Sae O-ring Boss Вl345, L345dt, & L355ss External Hydraulic System.pump:external Hydraulic Pump Made By Webster (077yc)direction Of Rotation..up To 30 Gpm. Up To 2500 Psi34"-16 Sae O-ring Boss. 1800 Psi (12411 Кра).2000 Psi (13790 Kpа)left Handrated Flow: (L305 Tractor) 9.3 Gpm (35 Liters/m) At 1800 Psi (12441 Kpa) @ 2800 Engine Rpm(L345 Tractor) 9.0 Gpm (34 Liters/m) At 2000 Psi (13790 Kpa) @ 2800 Engine Rpm(L355ss Tractor) 9.0 Gpm (34 Liters/m) At 2000 Psi (13790 Kpa) @ 2800 Engine Rpmsuction (In) Port Thread Spec's. 1-1/16"-12 Sae O-ring Bosspressure (Out) Port Thread Spec's 7/8"-14 Sae O-ring Bossinput Shaft. 34" Dia. With. 19 X 1.12 Lg Am Std Sq Key​
