Kubota LA351 Instructions for Parts Books - Instruction Manual
Part No. La351 Loader Book 01l001 Main Frame 100k081901l00202 Boom 100k081901l00301 Control Valve 100k081901l00302 Control Valve/control Lever 100k081901l00401 Control Valve [component Parts] 100k081901l00402 Control Valve [component Parts] 100k081901l005 Control Lever 100k081901l006 Cylinder-hydraulic Hose 100k081901l007 Cylinder (Boom) [component Parts] 100k081901l008 Cylinder (Bucket) [component Parts] 100k081901l009 Hydraulic Tube 100k081901l010 Hydraulic Hose 100k081901l011 Front Guard 100k081901l012 Accessories And Service Parts 100k0819 Ref.no Part No. Description Q'ty S.no. I/c Remarks Weight(Kgf)weight(Lb)010 75536-90110 Frame Main (Label) 1 59 129.8020 75546-56410 Label Danger 1 1 0 0030 75546-56450 Label Caution 1 1 0.001 0.0022040 01073-51435 Hex Bolt (M14*1.5*35 4 0.063 0.1386050 75599-33016 Washer Sprin Glock ( 4 0.08 0.176060 01073-51230 Hex Bolt (M12*1.25*3 4 0.041 0.0902070 75599-32015 Washer Plain (1/2) 4 0.01 0.022080 04512-50120 Washer Spring Lock ( 4 0 0090 01050-51235 Hex Bolt (M12*1.75*3 6 0 0100 04512-50120 Washer Spring Lock ( 6 0 0110 75537-90120 Frame Side Lh (Label 1 8.5 18.7120 75546-56430 Label Danger 3 1 0 0130 75546-56440 Label Warning 1 1 0 0140 75537-56350 Label Model 1 0 0150 75580-56370 Label Lubricate 1 0.001 0.0022160 75537-90130 Frame Side Rh (Label 1 9 19.8170 75546-56440 Label Warning 1 1 0 0180 75536-56710 Connector Side Frame 1 4 8.8190 75599-04625 Hex Bolt (9/16-18unf 2 0.056 0.1232200 75599-31066 Hex Nut (9/16-18unf) 2 0.03 0.066210 75599-33016 Washer Spring Lock ( 2 0.08 0.176220 75536-56810 Pin 2 0.74 1.628​
