Kubota LA350 Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Frame 01i01 Main Frame 100k0454boom 01i02 Boom 100k0454hydraulic System 01i03 Oil Pressure (1) 100k045401i04 Control Valve [component Parts] 100k045401i05 Cylinder 1 (Boom) [component Parts] 100k045401i06 Cylinder 2 (Bucket) Lh [component Parts] 100k045401i07 Cylinder 2 (Bucket) Rh [component Parts] 100k045401i08 Oil Pressure (2) 100k0454frame 01i09 Front Guard [option] 100k0454accessories 01i10 Accessories And Service Parts 100k0454 Ref.no Part No. Description Q'ty S.no. I/c Remarks Weight(Kgf)weight(Lb)010 75530-55010 Sub Frame 1 0 0020 75530-55630 Bracket Lh 1 0 0030 75530-55640 Bracket Rh 1 0 0040 01073-51230 Hex.bolt(M12*1.25*30 6 0.041 0.0902050 04512-50120 Washer,spring Lock(M 6 0.003 0.0066060 75599-32015 Washer,plain(1/2) 6 0 0070 75599-04630 Hex.bolt(9/16-18unf* 6 0 0080 75599-33016 Washer,spring Lock(9 6 0.08 0.176090 75599-31066 Hex.nut(9/16-18unf) 6 0 0100 01073-51245 Hex.bolt(M12*1.25*45 4 0.05 0.11110 04512-50120 Washer,spring Lock(M 4 0.003 0.0066120 75599-32015 Washer,plain(1/2) 4 0 0130 75530-55910 Connector,housing 2 0 0140 75530-55920 Spacer 2 0 0150 75599-32013 Washer,plain(3/8) 4 0.03 0.066160 01073-51035 Hex.bolt(M10*1.25*35 4 0.031 0.0682170 04512-50100 Washer,spring Lock(M 4 0.003 0.0066180 75599-03330 Hex.bolt(3/8-16unc*1 4 0 0190 75599-33013 Washer,sprng Lock(3/ 4 0 0200 75530-56010 Frame,side Lh 1 0 0210 75530-56350 Label,model 1 0 0220 75540-56360 Label,caution 1 0 0230 75530-56030 Frame,side Rh 1 0 0240 75530-56640 Bushing 1 0 0250 75540-62360 Label,control 1 0 0260 75540-56650 Label,warning 1 0 0270 75530-56710 Connector,side Frame 2 0 0280 75540-56720 Pin,spring 2 0 0290 75540-56810 Bolt,wedge 2 0 0300 75540-56820 Nut 1,lock 2 0 0310 75540-56830 Nut 2,lock 2 0 0​
