Kubota LA300 Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Frame 01i001 Main Frame 100k0455boom 01i002 Boom 100k0455hydraulic System 01i003 Oil Pressure (1) 100k045501i004 Control Valve [component Parts] 100k045501i00501 Cylinder 1 (Boom) [component Parts] 100k045501i00502 Cylinder 1 (Boom) [component Parts] 100k045501i00601 Cylinder 2 (Bucket) [component Parts] 100k045501i00602 Cylinder 2 (Bucket) [component Parts] 100k045501i007 Oil Pressure (2) 100k0455frame 01i008 Front Guard [option] 100k0455accessories 01i009 Accessories And Service Parts 100k0455 Ref.no Part No. Description Q'ty S.no. I/c Remarks Weight(Kgf)weight(Lb)010 75532-55010 Sub Frame 1 0 0020 75532-55710 Spacer 1 0 0030 01073-51035 Hex.bolt(M10*1.25*35 3 0.031 0.0682040 01073-51050 Hex.bolt(M10*1.25*50 3 0.038 0.0836050 75599-32013 Washer Plain(3/8) 6 0.03 0.066060 04512-50100 Washer Spring Lock(M 6 0 0070 01050-51260 Hex.bolt(M12*1.75*60 4 0 0080 75599-32015 Washer Plain(1/2) 4 0 0090 04512-50120 Washer Spring Lock(M 4 0 0100 75532-55910 Connector(Gear) 2 0 0110 75532-55920 Connector Lh (Hst) 1 0 0120 75532-55930 Connector Rh (Hst) 1 0 0130 75599-04635 Hex.bolt(9/16-18unf* 2 0 0140 75599-33016 Washer Spring Lock(9 2 0.08 0.176150 75599-31066 Hex.nut(9/16-18unf) 2 0 0160 75599-32016 Washer Plain(9/16) 2 For Mower Only 0.009 0.0198170 01073-51035 Hex.bolt(M10*1.25*35 4 0.031 0.0682180 04512-50100 Washer Spring Lock(M 4 0 0190 75532-56010 Frame Side Lh 1 0 0200 75532-56350 Label Model 1 0 0210 75540-56360 Label Caution 1 0 0220 75580-56370 Label Lubricate 1 0 0230 75532-56030 Frame Side Rh 1 0 0240 75540-56650 Label Warning 1 0 0250 75530-56710 Connector Side Frame 2 0 0260 75540-56720 Pin Spring 2 0 0270 75540-56810 Bolt Wedge 2 0 0280 75540-56820 Nut 1 Lock 2 0 0290 75540-56830 Nut 2 Lock 2 0 0300 75599-03535 Hex.bolt(1/2-13unc*1 2 0 0310 75599-31015 Hex.nut(1/2-13unc) 2 0 0320 75599-33015 Washer Spring Lock(1 2 0 0330 75540-62360 Label Control 1 0 0​
