Item Part No. Description Book Engine 010001 Crankcase 100k0490010002 Oil Pan 100k0490010003 Cylinder Head 100k0490010004 Gear Case 100k0490010005 Head Cover 100k0490010100 Main Bearing Case 100k0490010101 Camshaft And Idle Gear Shaft 100k0490010102 Piston And Crankshaft 100k049001010301 Flywheel [w/o Ind-pto] 100k049001010303 Flywheel [with Ind-pto] 100k0490010105 Fuel Camshaft 100k0490010200 Engine Stop Lever 100k0490010202 Injection Pump 100k0490010203 Injection Pump [component Parts] 100k0490010204 Governor 100k0490010205 Speed Control Plate 100k0490010206 Nozzle Holder And Glow Plug 100k0490010207 Nozzle Holder [component Parts] 100k049001050002 Water Flange And Thermostat[cab Type]100k0490010501 Water Pump 100k0490010600 Valve And Rocker Arm 100k049001060102 Inlet Manifold [cab Type] 100k049001090102 Upper Gasket Kit 100k0490010902 Lower Gasket Kit 100k0490010603 Exhaust Manifold/muffler 100k049001060403 Air Cleaner [cab Type] [old Type] 100k049001060404 Air Cleaner [cab Type] [new Type] 100k049001a002 Stop Solenoide/engine Stop Wire 100k049001a01003 Accelerator Lever [gst Type] [cabtype]100k049001a01004 Accelerator Lever [hst Type] [cabtype]100k049001a025 Accelerator Linkage [except Hsttype]100k049001a03002 Accelerator Rod [gst Type] [cabtype]100k049001a03003 Accelerator Rod [hst Type] 100k0490fuel System 01a10102 Fuel Tank [cab Type] 100k049001a110 Fuel Pipe And Fuel Filter 100k049001a130 Fuel Filter [component Parts] 100k0490cooling Water System 01a401 Fan 100k049001a41002 Water Pipe [cab Type] 100k049001a420 Radiator 100k049001a43002 Reserve Tank [cab Type] 100k0490electrical System 01a51502 Alternator [gst Type] [cab Type] 100k049001a51503 Alternator [hst Type] [cab Type] 100k049001a52002 Alternator [component Parts][cab Type]100k049001a525 Starter 100k049001a530 Starter [component Parts] 100k049001a53502 Battery [cab Type] 100k049001b10205 Switch 1 [gst Type] [cab Type] 100k049001b10206 Switch 1 [a] [hst Type] [cab Type][old Type]100k049001b10207 Switch 1 [a] [hst Type] [cab Type][new Type]100k0490
