Kubota L4200 wheel alignment
Kendra
I noticed that my new L4200 has the front wheels in an excessive positive camber. Is this normal?
I'm new to this, so please bear with me LOL
I think this has a lot to do with keeping the stress off the wheel and axle bearings. When there's no camber or even negative camber, the tire's contact patch ends up farther from the bearings, which cranks up the leverage and load.
This is super important, esp when you're working with a fully loaded front-end loader!
Yep, a bit of positive camber is normal on these tractors. It helps with steering and reduces stress on the front end when that loader's doing work.
Totally normal for these tractors when unloaded and once you put some weight on the front end or hook up a loader, it usually evens out, welcome to the tractor life
