Kubota L4150DT-N Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01e001 Crankcase 100k001701e002 Oil Pan 100k001701e003 Cylinder Head 100k001701e004 Gear Case 100k001701e005 Main Bearing Case 100k001701e006 Manifold 100k001701e007 Valve And Rocker Arm 100k001701e008 Cylinder Head Cover 100k001701e009 Camshaft 100k001701e010 Piston And Crankshaft 100k001701e011 Flywheel And Starter 100k001701e012 Injection Pump 100k001701e013 Fuel Camshaft 100k001701e014 Nozzle And Glow Plug 100k001701e015 Governor 100k001701e016 Speed Control Plate 100k001701e017 Compensator 100k001701e018 Idling Apparatus 100k001701e019 Dynamo And Fan 100k001701e020 Thermostat 100k001701e021 Water Pump 100k0017section Parts 01e022 Oil Filter [section Parts] 100k001701e023 Injection Pump [section Parts] 100k001701e024 Starter [section Parts] 100k001701e025 Dynamo [section Parts] 100k0017electrical System 01t001 Battery Support 100k0017front Axle 01t002 Front Axle Bracket 100k0017clutch 01t003 Clutch 100k001701t004 Clutch Lever 100k001701t005 Clutch Pedal 100k0017steering 01t006 Power Steering 100k001701t007 Steering Wheel Tilet Lever 100k001701t008 Steering Wheel 100k001701t009 Drag Link 100k001701t010 Power Steering Oil Line (Manual Shuttle) 100k001701t011 Power Steering Oil Line (Hyd Ssuttle) 100k001701t012 Power Steering Oil Tank 100k0017engine Control 01t013 Throttle Lever 100k001701t014 Throttle Pedal 100k0017chassis 01t015 Front Roof 100k001701t016 Front Grille 100k001701t017 Bonnet 1 100k001701t018 Bonnet 2 100k001701t019 Seat 100k0017clutch 01t020 Main Clutch Case 100k0017transmission 01t021 Main S-change Case 100k001701t022 Pto Clutch Valve 100k001701t023 1st Shaft (Manual Shuttle) 100k001701t024 1st Shaft (Hyd.shuttle) 100k001701t025 2nd Shaft (Manual Shuttle) 100k001701t026 2nd Shaft (Hyd.shuttle) 100k001701t027 Main Shaft 100k001701t028 Counter Shaft 100k001701t029 Hi-lo S-change Shaft 100k0017pto 01t030 Pto Shaft 100k0017transmission 01t031 Clutch Case Support 100k001701t032 Transmission Case 100k001701t033 Rear Differential 100k001701t034 Diff Bearing Support 100k0017​
