Kubota Front Loader Models LA513 LA723 LA853 Assembly Instructions Printed in U.S.A. Code No.7J266-6915-1 - Instruction Manual
This manual contains procedures intended to assist the dealer in unpacking and assembling the product before delivering to the customer. The customer's purchase is based on confidence in both the product and your store. Observe the procedures in this manual to assemble and adjust equipment for your customer's safety and satisfaction. When fully assembled, check function of each chart and feature.The following safety alert symbol mark and indication are found throughout this manual in steps where particular attention is required so as to ensure your safety and to avoid product damage. Observe the instructions in these warnings where indicate c.(1)(2)DANGER: Indicates an imminently hazardous situation which, if not avoided. will result in death or serious injury. Indicates a potentially hazardous situation which, if not avoided, could result in death or serious injury. Indicates a potentially hazardous situation which, if not avoided, may result inminor or moderate injury.lndicates that equipment or property damage could result if instructions are not followed. Gives helpful information...4 WARNING: A CAUTION: IMPORTANT:NOTE:2. SAFETY To prevent accidents, read through the following items before starting work, and always regard safety when working. lt is your responsibility to ensure your safety on the job.(1) Preparations1. Select a work site which is level,has sufficient space, and is not close to dangerous objects.2. Avoid poorly ventilated rooms.Asphyxiation from exhaust fumes is always a possibility that accompanies running an engine.ffif*& #t\3. Working clothes which may be pinched or caught in the equipment must not be worn.Loose clothing can cause serious injury or death.4. Always wear a mask and protective goggles during work when dust or flying debris maybe thrown by equipment.(2) Assembly and adjustments1. Before assembling equipment,read the assembly instructions for the product to become familiar with the equipment and procedures.2. Use only adequate and require equipment, tools and instruments (e.9. torque wrench, battery hydrometer and etc.).Set the parking brake and block wheels to prevent machine (or tractor) movement.Lower the attachment or implement to the ground before assembling or adjusting equipment. Before working undersuspended or raised equipment,support the equipment orattachment to prevent themachine from falling or movingout of olace.6. Keep fire from cigarettes,matches or other ignitionsources away from fuel, oil,antifreeze and other flammablematerials.​
