Item Part No. Description Book Engine 011001 Crankcase 100k0828011002 Oil Pan 100k0828011003 Cylinder Head 100k0828011004 Gear Case 100k0828011005 Head Cover 100k0828011006 Oil Filter 100k0828011007 Dipstick And Guide 100k0828011100 Main Bearing Case 100k0828011101 Camshaft And Idle Gear Shaft 100k0828011102 Piston And Crankshaft 100k0828011103 Flywheel 100k0828011105 Fuel Camshaft And Governorshaft100k0828011200 Idle Apparatus 100k0828011202 Injection Pump 100k0828011204 Governor 100k0828011205 Speed Control Plate 100k0828011206 Nozzle Holder And Glow Plug 100k0828011207 Nozzle Holder [component Parts]100k0828011301 Fuel Pump(Mechanical) 100k0828011400 Dynamo 100k0828011401 Dynamo [component Parts] 100k0828011500 Water Flange Andthermostat100k0828011501 Water Pump 100k0828011600 Valve And Rocker Arm 100k0828011601 Inlet Manifold 100k0828011602 Exhaust Manifold 100k0828011603 Air Cleaner 100k0828011605 Muffler 100k0828011700 Hydraulic Pump 100k0828011701 Hydraulic Pump [component Parts]100k0828011900 Upper Gasket Kit 100k0828011901 Lower Gasket Kit 100k082801a001 Accelerator Lever 100k082801a030 Acceleraotr Rod 100k0828fuel System 01a101 Fuel Tank 100k082801a11002 Fuel Pipe 100k082801a130 Fuel Filter [component Parts]100k0828cooling Water System 01a40102 Fan 100k082801a41002 Water Pipe 100k082801a42002 Radiator 100k082801a430 Reserve Tank 100k0828electrical System 01a510 Stop Solenoid 100k082801a525 Starter 100k082801a530 Starter [component Parts] 100k082801a535 Battery 100k082801b101 Switch 100k082801b115 Panel Board 100k082801b120 Panel Board [component Parts]100k082801b301 Head Light 100k082801b302 Hazard Light 100k082801b304 Tail Light 100k082801b310 Winker Lamp 100k082801b50102 Electrical Wiring 100k0828
