Replacing my T2290KWT-48's drive belt
Lekim
I'm trying to replace the hydro drive belt and pulleys on my T2290KWT-48, but it's a real pain. The design is so complicated that I'm having trouble accessing the belt system. Any tips on how to make this easier?
Tough due to tight access, removing the mower deck and rear tires can help give you more room. You can check the manual for the belt routing and consider using a belt tool or long handled pliers to guide it onto the pulleys more easily. Good luck
You should drop the mower deck completely and get the rear end up on ramps or jack stands for better access, also, loosen the tension spring slowly
