no left hand controls
2019 ssv65 i changed the hydrolic oil, sucked out with shop vac. changed both filters, forgot to fill them with hydro fluid(not sure if that matters) re-filled resevoir tank. started skid steer, thought i was ok to warm up, left for 20 min. came back and tank was low. put another 2 gallons in. closed cab and pushed green park button and right joystick work but left one (wheels) does not. doesnt make any noise whatsoever. its as if i did not even push the park release. loader worked perffectly fine prior. Anybody have any ideas
With the amount of electronics on these things now it might be a good idea to raise the cab and check connections on that side. Maybe something got pulled tight enough to come unplugged? Or you might check fuses?
Sounds like you might have let some air into the system when you changed the filters without filling them up. I've seen this happen before you think everything's good after topping off the reservoir but the hydraulics won't build pressure until you properly bleed it out. You might want to loosen the lines at the pump and check if the charge side is working as it should.
