M7151 4WD
gaf1975
My M7151 wont engage 4WD the switch and lights seem to working ok.
anyone had similair problem
thanks
Mine had a similar problem after a muddy job when the front axle actuator got all gummed up. The lights and switch were working fine, but I couldn't get 4WD to engage. I had to clean it out and cycle it a few times before it finally caught again. Dealing with mud-related issues can be tricky.
I had a similar scare after doing some brush clearing. My 4WD wouldn’t kick in, even though the indicator lights were showing it was on. It turned out to be a loose connector near the axle. A quick tighten and it was back to normal. Just had to find that loose connection.
I faced the same issue with my 7040. Turns out, the fuse for the actuator was weak not blown so everything seemed normal, but it just wouldn’t engage. Once I swapped it out, it clicked back into place. Chasing those electrical gremlins is always frustrating.
