Kubota Zero Turn Mower V1505-T-E4 Reformer System Diagnosis Manual Printed in Japan Code No.9Y110-04120 - KiSC issued 12, 2016 A - Technical Manual
SAFETY WORKING• Do not work on the machine while under the influence of alcohol, medication, or other substances or while fatigued.• Wear close fitting clothing and safety equipment appropriate to the job.• Use tools appropriate to the work. Makeshift tools, parts, and procedures are not recommended.• When servicing is performed together by two or more persons, take care to perform all work safely.• Do not touch the rotating or hot parts while the engine is running.• Never remove the radiator cap while the engine is running, or immediately after stopping. Otherwise, hot water will spout out from radiator. Only remove radiator cap when cool enough to touch with bare hands. Slowly loosen the cap to first stop to relieve pressure before removing completely.• Escaping fluid (fuel or hydraulic oil) under pressure can penetrate the skin causing serious injury. Relieve pressure before disconnecting hydraulic or fuel lines. Tighten all connections before applying pressure.• Wear a suitable hearing protective device such as earmuffs or earplugs to protect against objectionable or uncomfortable loud noises.• Do not open high-pressure fuel system.High-pressure fluid remaining in fuel lines can cause serious injury. Do not disconnect or attempt to repair fuel lines, sensors, or any other components between the high-pressure fuel pump and injectors on engines with high pressure common rail fuel system.• High voltage exceeding 100 V is generated in the ECU and injector. Pay sufficient caution to electric shock when performing work activities. FIRES• Fuel is extremely flammable and explosive under certain conditions. Do not smoke or allow flames or sparks in your working area.• To avoid sparks from an accidental short circuit,always disconnect the battery negative cable first and connect it last.• Battery gas can explode. Keep sparks and open flame away from the top of battery, especially when charging the battery.• Make sure that no fuel has been spilled on theengine.​
