SAFETY STARTING SAFETY INSTRUCTIONS• Do not start the engine by shorting across starter terminals or bypassing the safety start switch.• Do not alter or remove any part of machine safety system.Before starting the engine, make sure that all shiftlevers are in neutral positions or in disengaged positions.Never start the engine while standing on ground.Start the engine only from operator's seat.SAFETY WORKING • Do not work on the machine while under the influence of alcohol, medication, or other substances or while fatigued. Wear close fitting clothing and safety equipment appropriate to the job.Use tools appropriate to the work. Makeshift tools,parts, and procedures are not recommended.When servicing is performed together by two or morepersons, take care to perform all work safely.Do not work under the machine that is supported solely by a jack. Always support the machine by safety stands.Do not touch the rotating or hot parts while the engine is running.Never remove the radiator cap while the engine isrunning, or immediately after stopping. Otherwise,hot water will spout out from radiator. Only remove radiator cap when cool enough to touch with barehands. Slowly loosen the cap to first stop to relieve pressure before removing completely.Escaping fluid (fuel or hydraulic oil) under pressurecan penetrate the skin causing serious injury. Relieve pressure before disconnecting hydraulic or fuel lines.Tighten all connections before applying pressure.AVOID FIRES • Fuel is extremely flammable and explosive under certain conditions. Do not smoke or allow flames orsparks in your working area.To avoid sparks from an accidental short circuit,always disconnect the battery negative cable first and connect it last.Battery gas can explode. Keep sparks and open flame away from the top of battery, especially when charging the battery.Mark sure that no fuel has been spilled on the engine.
