This symbol, the industry's" "Safety Alert Symbol", is used throughout this manual and on labels onthe machine itself to warn ofof the possibility of personal injury. Read these instructions carefully.-It is essential that you read the instructions and safety regulations before you attempt to repair or usethis unit.DANGER : Indicates an imminently hazardous situation which, if not avoided, will result indeath or serious injury.WARNING : Indicates a potentially hazardous situation which, if not avoided, could result indeath or serious injury.CAUTION Indicates a potentially hazardous situation which, if not avoided, may result inminor or moderate injury.IMPORTANT : Indicates that equipment or property damage could result if instructions are not followed.NOIOTE : Gives helpful information.BEFORE SERVICING ANDSTOKubsta.AND REPAIRINGRead all instructions and safety instructions in thismanual and on your machine safety decals.Clean the work area and machinePark the machine ona firm and level ground, and setthe parking brakeLower the implement to the ground.Stop the engine, and remove the key. Disconnect the t battery negative cab Hang a "DO NOT OPERATE" tag in operator station.
