TRACTORCareful operation is your best insurance against anaccident.Read and understand this manual carefully beforeoperating the tractor.All operators, no matter how much experience they mayhave, should read this and other related manuals beforeoperating the tractor or any implement attached to it. It isthe owner's obligation to instruct all operators in safeoperation.1. Know your equipment and its limitations. Read thisentire manual before attempting to start and operatethe tractor.2. Pay special attention to the danger, warning andcaution labels on the tractor.3. Do not operate the tractor or any implement attachedto it while under the influence of alcohol, medication,controlled substances or while fatigued.4. Carefully check the vicinity before operating tractor orany implement attached to it. Do not allow anybystanders around or near tractor during operation.5. Before allowing other people to use your tractor,explain how to operate and have them read thismanual before operation.6. Never wear loose, torn, or bulky clothing aroundtractor. It may catch on moving parts or controls,leading to the risk of an accident. Use additional safetyitems, e.g. hard hat, safety boots or shoes, eye andhearing protection, gloves, etc., as appropriate orrequired.7. Do not allow passengers to ride on any part of thetractor at anytime. The operator must remain in thetractor seat during operation.8. Check brakes, linkage pins and other mechanicalparts for improper adjustment and wear. Replace wornor damaged parts promptly. Check the tightness of allnuts and bolts regularly. (For further details, see"PERIODIC SERVICE OF THE TRACTOR" section.)9. Keep your tractor clean. Dirt, grease, and trash buildup may contribute to fires and lead to personal injury.10.Use only implements meeting the specifications listedunder "IMPLEMENT LIMITATIONS" in this manual orimplements approved by KUBOTA.11.Use proper weights on the front or rear of the tractor toreduce the risk of upsets. When using the front loader,put an implement or ballast on the 3-point hitch toimprove stability. Follow the safe operatingprocedures specified in the implement or attachmentmanual.12.Do not modify the tractor. Unauthorized modificationmay affect the function of the tractor, which may resultin personal injury.C CAB, ROPS1. KUBOTA recommends the use of a CAB or Roll OverProtective Structures (ROPS) and seat belt in almostall applications. This combination will reduce the riskof serious injury or death, should the tractor be upset.Check for overhead clearance which may interferewith a CAB or ROPS.2. Set parking brake and stop engine. Remove anyobstruction that may prevent raising or folding of theROPS. Do not allow any bystanders. Always performfunction from a stable position at the rear of the tractor.Hold the top of the ROPS securely when raising orfolding. Make sure all pins are installed and locked.3. If the CAB or ROPS is loosened or removed for anyreason, make sure that all parts are reinstalledcorrectly before operating the tractor.4. Never modify or repair any structural member of aCAB or ROPS because welding, bending, drilling,grinding, or cutting may weaken the structure.5. A damaged CAB or ROPS structure must be replaced,not repaired or revised.6. If any structural member of the CAB or ROPS isdamaged, replace the entire structure at your localKUBOTA Dealer.7. If the tractor is equipped with a foldable ROPS it maybe temporarily folded down only when absolutelynecessary for areas with height constraints.(There is no operator protection provided by the ROPSin the folded position. For operator safety the ROPSshould be placed in the upright and locked positionand the seat belt fastened for all other operations.)8. Always use the seat belt if the tractor has a CAB orROPS.Do not use the seat belt if a foldable ROPS is down orthere is no ROPS. Check the seat belt regularly andreplace if frayed or damaged.
