PISTON AND CRANKSHAFT PISTON ET VILEBREQUIN(B) (B)SNo A<=15000 : 14000 15000030020040050 080040010DESI ONATICHSJEUDE BEGMENTSGTY/8 HGTE/8AXXXX BEMARQUESExple 1Ехат -21 ExempleREFERENCE PART NAMЕ010 15000-0000-0 PISTO STONPRITO PISTON1 AXE DE15800-10002 P PMETON AXE H POITE000 15800-2000-0 ASSY PETOH RING15000-9000-0 SEGMENTS Exampl(1)Fig. No. Represents No comesponding to each group name.Specifications.. The types and deetirations of sisler models are indicated. These indications are given to(for sister models) le thair relevant pages in this book.Componarts The components of an assembly are idenlified by a bracket ofdotted ines.④ Point Irdicates that the parts is not sold independenlly.The assembly (Ref. No 050) conlaining the part needs lo be ordered.REF.No sference numbers are assigned to parts in the lustration.The code number ofapart inthe illustration can be identified by refemring io the same reference rumber in the parts listModel name The name of the basic model is indicaled in this column. Other applicable model aruindicated on the "REMARKS" column 3S. No Indicalesa group of serial numbers io which a design change is opplied.(serial No.)Engine Serial No.B7J 0001B 7 K A001Lower 4 digits in Numerats or Alphabetical letter (A to Z) and Numerals (start 0001 io max 2909)5th dipit Alphabetical letter (Month of manufactura).Month 12 45 7 50 11 12AB CD E GH JK LM NP OP яT UM WYZGth digit...** umerals or Alphabelical letler (Yosro (ma acture)Yaar10 20 303 04 06 09 07 08 09 10 11w Y12 3 4 6 9 AYear 12 13 14 165 10 17 18 19 20 21 22 23 244 25C D E F GH K L M N R71h digil Numarals or Alphabelical letter (The tactoryline Identifying)Identifying 1 2 4 T ΠALC.. Incicates the interchangeability of parts due to design change (interchange ebty)Example-1indicarles thal a new partcan replace an old part, but not vice versa15800-0000-0s applicable tothe first serial number to 8. No. 15000.15800-0000-2 is applicable to the first serial number and aboveExample-2 indicales thal the new and old parts are not inierchangeable.15800-1000-0 is applicable to the nrsi serial number to S. Мo. 15000.15800-1000-2 is applicable to S. No. 15001 and above.Example-3ndicales thel the new and old parts are interchangeable. Both 15800-2000-0 and15830-2000-0 are applicable to the first serial numberand above.REMARKS In this column, enter other applicable modelnames, dimersions and other special items.The following symbols and abbreviations are used throughout this book2912.00-15 Tire sze s...m² sqmm.mm²cum..m .mm...mm D Clameler L.. Length
