Kubota Tractor Model B2410 Operator's Manual Reprinted in U.S.A. August 2003 - English (U.S.A.) Code No. 6C140-6311-2 - Instruction Manual
Careful operation is your best insurance against anaccident.Read and understand this section carefully beforeoperating the tractor.All operators, no matter how much experience theymay have had, should read this and other relatedmanuals before operating the tractor or anyimplement attached to it. It is the owner's obligationto instruct all operators in safe operation.1. BEFORE OPERATING THE TRACTOR1. Know your equipment and its limitations. Readthis entire manual before attempting to start andoperate the tractor.2. Pay special attention to the danger, warning andcaution labels on the tractor itself.3. KUBOTA recommends the use of a Roll OverProtective Structures (ROPS) and seat belt inalmost all applications. This combination willreduce the risk of serious injury or death, shouldthe tractor be upset.If the ROPS is loosened or removed for anyreason, make sure that all parts are reinstalledcorrectly before operating the tractor.Never modify or repair a ROPS because welding,bending, drilling, grinding, or cutting any portionmay weaken the structure.A damaged ROPS structure must be replaced, notrepaired or revised. If any structural member ofthe ROPS is damaged, replace the entire structureat your local KUBOTA Dealer.6. Carefully check the vicinity before operatingtractor or any implement attached to it. Check foroverhead clearance which may interfere with aROPS. Do not allow any bystanders around ornear tractor during operation.7. Before allowing other people to use your tractor,explain how to operate and have them read thismanual before operation.8. Never wear loose, torn, or bulky clothing aroundtractor. It may catch on moving parts or controls,leading to the risk of accident. Use additionalsafety items, e.g. hard hat, safety boots or shoes,eye and hearing protection, gloves, etc., asappropriate or required.9. Do not allow passengers to ride on any part of thetractor at anytime. The operator must remain inthe tractor seat throughout operation.10. Check brakes, clutch, and other mechanical partsfor improper adjustment and wear. Replace wornor damaged parts promptly. Check the tightnessof all nuts and bolts regularly. (For further details,see Maintenance section.)11. Keep your tractor clean. Dirt, grease, and trashaccumulations contribute to fires and lead topersonal injury.12. Use only implements meeting the specificationslisted under IMPLEMENT LIMITATIONS in thismanual and use only implements approved byKUBOTА.13. Use proper weights to front or rear of tractor toreduce the risk of upsets. When using the frontloader, put the implement or ballast on 3-pointhitch to improve stability. Follow the safeoperating procedures specified in the attachedmanual to the equipment.14. The narrower the tread, the greater the risk of atractor upset. For maximum stability, adjust thewheels to the widest practical tread width.(See "TIRES, WHEELS AND BALLAST" Section)AF-11773(1) ROPS(2) Seat belt4. Always use the seat belt when any ROPS isinstalled. Do not use the seat belt if a foldableROPS is down or there is no ROPS. Check the seatbelt regularly and replace if frayed or damaged.5. Do not operate tractor or any implement attachedto it while under the influence of alcohol,medication, or other substances or whilefatigued.F-7064(1) Rear wheels(1(A) Tread Width15. Do not modify the tractor. Unauthorizedmodification may affect the function of thetractor, which may result in personal injury.​
