Kubota Rotary Mower Models RC40-G RC44-G RC48-G Mower Deck Manual Code Na. 70712-7111-5 - Instruction Manual
1. Keep bystander from the machine2. Prior to bemight e picload upmower. Mow only in daygood artificial light.3. Do not wear loose clothing while operating themower. Loose clothing could become entangled in moving parts, causing personał injury.4. Do not stand on the mower.5. Before dismounting the tractor:a) Shut off the engine,b) remove the key,c) set the parking brake,d) allow the blades to stop.6. Securely tighten all hardware before operatingthe mower.7. Read this manual and the tractor operator'smanaual before operating mower. Allow only aproperly trained person to operate the tractor.8. Before starting the engine, disengage the frontPTO and sit on the seat.9. Hillside operation is dangerous and cannot berecommended. If it is necessary to mow on ahillside, use extreme caution. Never mowacross the face of a slope.10. While making turns operating in rough terrain,reduce tractor speed.11. Upon striking a foreign object, stop and inspectthe tractor and the mower for damage. Repairthe damage before resuming equipment operation.12 If the mower discharge chute becomes clogged,stop the tractor; disengage the mower drive;shut off the engine and, remove the key; andclean out the chute before continuing.13. Know how to stop the mower and engine quickly. Be prepared for any emergency situation.14. When mowing in rough terrain or in high grass,set the mower at the highest cutting level toreduce the possibility of the mower strikingdebris or hidden objects.15. Before operating the tractor in reverse, look tosee if the area is clear of all objects.16. Do not operate the mower without all shieldsand guards in place.17. Never attempt to make adjustment or repairsof any kind when the tractor and mower arerunning. Shut off the engine, remove the keyand allow the blades to stop.18. Replace damaged or illegible safety decals.See next page for required labels.​
Instruction manual attachments
