Item Part No. Description Book Mower 03h001 Universal Joint 100a026803h010 Bevel Gear Case 100a026803h015 Input Shaft/center Pulley 100a026803h020 Pulley Holder/blade(Center) 100a026803h030 Pulley Holder/blade(Left) 100a026803h100 Tension Pulley/mower Belt 100a026803h200 Mower Deck And Cover 100a026803h300 Gauge Wheel 100a026803h500 Front Link Lever 100a026803h800 Mower Label 100a0268 010 K5273-32030 Assy Joint Universal 1 0 0020 01123-50825 Bolt 1 0.013 0.0286 Ref.no Part No. Description Q'ty S.no. I/c Remarks Weight(Kgf)weight(Lb)010 K5617-33130 Stay Bevel Case Lh 1 0 0020 K5763-44250 Nipple Grease 1 0.01 0.022030 K5763-27340 Shim Adjust 1 0.001 0.0022040 04816-06120 O Ring 1 0.002 0.0044050 K5617-33220 Reamer Bolt 2 0.023 0.0506060 K5617-33230 Reamer Bolt 2 0.031 0.0682070 K5617-33150 Stay Bevel Case Rh 1 0 0080 01123-51025 Bolt 2 0.02 0.044090 01173-51030 Bolt 2 0.023 0.0506100 04512-60100 Washer Spring 6 0.002 0.0044110 02118-50100 Nut 4 0.005 0.011120 K5243-33112 Case Bevel Gear Rh 1 0.45 0.99130 K5243-33133 Case Bevel Gear Lh 1 0.45 0.99140 K5761-33250 Plug Breather 1 0.006 0.0132150 06331-35016 Plug 1 0.04 0.088160 04724-00160 Gasket 1 0.003 0.0066170 01754-50840 Bolt Flange 5 0.02 0.044180 02751-50080 Nut Flange 5 0.006 0.0132190 08511-00810 Bush 2 0.003 0.0066200 04717-00800 Washer With Rubber 1 0.001 0.0022210 01153-50812 Bolt 1 0.008 0.0176
